[SOLVED] Registry key modification problem
MorganeDeveho
Registration: July 20, 2021 - 2:42 PM
July 26, 2021 - 10:14
I have a problem concerning a registry key modification package.
Here is the code:
    registry_setstring(HKEY_CURRENT_USER, "Software\\SAP BusinessObjects\\Suite XI 4.0\\Crystal Reports\\FetchOptions",'NTablesMax','7530', type=REG_DWORD)
    pass
wapt cannot read the type and gives me an error: FATAL ERROR: ValueError: Could not convert the data to the specified type.
elelay
Registration: Oct 20, 2020 - 12:39
July 26, 2021 - 11:16
Hello Morgane,
Python doesn't like spaces very much. For escapes, you need to put an 'r' before the string. In your case, it would look like this:
    registry_setstring(HKEY_CURRENT_USER, r"Software\SAP BusinessObjects\Suite XI 4.0\Crystal Reports\FetchOptions",'NTablesMax','7530', type=REG_DWORD)
    pass
PS: (From memory), wapt already adds the two backslashes
Is this better?
Étienne
WAPT Server version: 2.0 Enterprise
Console installed on a Windows Server 2019
Debian 10 Buster server
MorganeDeveho
July 26, 2021 - 11:26
Unfortunately, no.
It still displays the same error: FATAL ERROR: ValueError: Could not convert the data to the specified type
elelay
July 26, 2021 - 11:42
Looking at the Python method, when using a DWORD key, you must use an integer , not a string, as an argument.
So, 7530 without the single quotes.
MorganeDeveho
July 26, 2021 - 11:54
Thank you, the order is no longer showing an error, but there is a new problem.
The data should be 0x00007530 (30000)
and with the command it becomes 0x00001d6a (7530)
elelay
July 26, 2021 - 11:59
Ah, okay.
So you wanted to change the value to '0x00007530' at first, I didn't understand.
In that case, you just need to replace 7530 with 30000, I think.
MorganeDeveho
July 26, 2021 - 4:25 PM
Thank you very much.
It works
