[SOLVED] Force an error
seb b
Registration: Oct 26, 2017 - 3:12 p.m.
August 26, 2021 - 10:31
Hello
a WAPT 2.0 Enterprise
SRV Debian
development machine running Windows 10.
I have an old program that uses the Access 2007 framework that needs to be installed on machines where Office 2016 (which is part of a larger software suite) also needs to be installed.
Therefore, it's essential that this program be installed last, otherwise the Office installation will fail.
How can I force the package to throw an error if Office isn't installed (so I can try again later)?
I know it's possible, but I can't find the information...
I should mention that the dependencies are, in my opinion, unusable because the software suite is deployed across a wider area than the program in question.
Thank you and have a good day.
August 26, 2021 - 12:26
Hello Sébastien,
if possible, add the Office 2016 package as a dependency of this package to ensure it's installed first.
Otherwise, you can run the command `error('MS Office 2016 must be installed first')`.
Regards,
seb b
August 26, 2021 - 1:32 PM
Unfortunately, I cannot use dependencies (several versions of Office are deployed, some belonging to a group and others not, in short, it makes too many different cases to manage).
But great for the function
error
That's exactly what I was looking for.
THANKS.
