[RESOLVED] Deployment issue
Gaetan
Registration: August 8, 2019 - 10:16
September 1, 2021 - 10:01
Via the control file, you can put the architecture, the OS version, the maturity etc. which are filters for the workstation.
Scud
Registration: March 23, 2020 - 3:37 PM
September 1, 2021 - 10:19
Hi,
it's all good, I found the solution!!!
It's really simple (but not logical to me).
While testing my package, I had marked it as DEV. Apparently, you can't deploy applications while they're marked as DEV.
I recompiled my package in PROD and "miracle," everything works!
Thanks again for your help.
It's always great to find people so responsive.
Thanks again.
Gaetan
September 1, 2021 - 10:55
By default, all workstations are in PROD. ;)
Don't forget to mark the topic as [RESOLVED].
