[SOLVED] Editing a configuration file
yandre
Registration: Oct 08, 2019 - 11:47
August 30, 2021 - 4:02 PM
I'm trying to modify the Nextcloud configuration file C:\Users\%login%\AppData\Local\Nextcloud\nextcloud.cfg in order to add the following lines to the [Global] section:
logDebug=false
logExpire=1
logDir=C:/tmp
Thank you in advance, best regards.
August 30, 2021 - 5:11 PM
you can use the following package as a guide: https://store.wapt.fr/store/tis-wapt-conf-policy
Regards,
yandre
September 3, 2021 - 4:34 PM
Thank you very much.
Very practical:
inifile_writestring()
