MSI package update
nico62100
Registration: Sep 14, 2021 - 09:49
September 14, 2021 - 10:20
I'm trying to update an MSI package (it's Flowcode, https://flowcode.co.uk/download/ )
(The previous version of the package is correctly installed with wapt)
The line:
install_msi_if_needed('FlowcodeV9_Installer.msi')
It gives me an error; in fact, if the software is already installed, it does not update it. I do not get an error when the old version is not installed.
I imagine Wapt can't detect that the versions differ, or have I forgotten an argument? I tried adding:
install_msi_if_needed('FlowcodeV9_Installer.msi', remove_old_version=true)
and I also tried adding a def update_package() section, but it didn't change anything.
Thank you for your help ;)
Nicolas
(WAPT 1.3.5 and workstations running Win10 Education)
vcardon
September 14, 2021 - 5:44 PM
WAPT 1.3.5 ?
I kindly suggest you update, as you won't find many people with answers to your question.
nico62100
September 15, 2021 - 09:11
Thank you for your reply.
Unfortunately, I don't have access to the server; otherwise, I would have updated it. :roll:
