Security release for WAPT 1.8.2 and WAPT 2.0
Find official announcements related to WAPT here.
October 7, 2021 - 9:04 PM
A security release for Wapt 2.0 Enterprise and Wapt 1.8.2 Enterprise and Community Editions has just been published. The changelog and CVSS scores are available below. WAPT 2.1 is not affected. For the update, please follow the documentation at .
https://www.wapt.fr/en/doc .
Best regards,
Denis.
Changelog 2.0.0.9470
This is a security release All Wapt 2.0 version below 2.0.0.9470 are affected
* [SEC] fix for vuln in urllib3 CVE-2021-33503 (CVSS Score: 7.5 High, CVSS:3.1/AV:N/AC:L/PR:N/UI:N/S:U/C:N/I:N/A:H)
* [SEC] Sanitize filename used when downloading files on customer local. (CVSS Score: 7.5 High, CVSS;3.1/AV:L/AC:H/PR:H/UI:N/S:C/C:H/I:H/A:H/E:U/RL:O/RC:C)
Enforced on wget and local filenames for downloaded packages (chars '\\' '..' @ | ( ) : / , \ [ ] < > * ? ; ` \n are removed or replaced)
* [UPD] Wapt.remove: reraise exception if there is exception in uninstall script
return traceback in 'errors' key
return code 3 if there are errors when removing packages in wapt-get remove
* [FIX] handles wildcards in certificates in waptconsole config and create waptsetup
update UI in external repositories config when setting CA bundle
* [FIX] use PackageEntry.localpath only for local status of a package.
* [UPD] split PackageEntry non_control_attributes into repo_attributes and local_attributes
local_attributes are not put into Packages index as they are not relevant for remote access.
* [UPD] update python modules requirements following urllib3 upgrade
idna==3.2 (from 2.10)
certifi==2021.5.30 (from 2020.12.5)
requests==2.26.0 (from 2.25)
urllib3==1.26.6 (from 1.26.5)
Changelog 1.8.2.7388
This is a security release. All Wapt 1.8 version belos 1.8.2.7388
Security changelog wapt-1.8.2.7388*
* [SEC] Sanitize filename used when downloading files on local client. (CVSS Score: 7.5 High, CVSS;3.1/AV:L/AC:H/PR:H/UI:N/S:C/C:H/I:H/A:H/E:U/RL:O/RC:C)
* [FIX] Waptconsole config: When retrieving server side https certificate don't write UTF16 string for in waptconfig. Remove wildcards from CN of certificate to compose cert filename.
certifi==2021.5.30
chardet==3.0.2
idna==2.8
requests==2.21.0
urllib3==1.24.3
