[SOLVED] Activate an xpi Firefox plugin
Patrice_minagri
Registration: Oct 21, 2016 - 4:56 p.m.
October 11, 2021 - 1:55 PM
I'd like to know if any of you have had to automatically install a plugin (XPI file) to Firefox via WAPT?
For me, the plugin installation went smoothly; Firefox recognized it after the package ran. However, the plugin is disabled by default and needs to be activated manually.
Do you think it's possible to automatically activate the plugin after installation (via WAPT, of course)?
Thank you for your help.
Patrice
WAPT 2.6.1.17787
florentR2
Registration: February 13, 2020 - 5:23 PM
October 11, 2021 - 4:02 PM
I've never tested it with a file:// URL, but via policies.json you can provide a web URL like this and the extension is indeed activated:
"ExtensionSettings": {
      "uBlock0@raymondhill.net": {
        "install_url": "https://addons.mozilla.org/firefox/downloads/file/3719054/ublock_originXXX.xpi",
        "installation_mode": "normal_installed"
Patrice_minagri
October 11, 2021 - 4:12 PM
Oh, thank you for the tip.
I'll take a closer look at that. :P
WAPT 2.6.1.17787
