I'm having trouble installing packages on machines running Ubuntu 21.04 with WAPT agents version 2.1.0.
I can't see the packages installed on the machine in the General tab. When I try to install them, the machine's status changes to "TO-UPGRADE" and nothing happens. Even running the package installation command from the machine itself doesn't find any packages.
(Server console used under Windows 10 and WAPT Enterprise 2.1.0.10550 installed on a Debian 10 server).
(Related to the previous topic viewtopic.php?f=13&t=2803)
Thank you in advance,
Best regards.
[RESOLVED] No longer possible to implement packages
- WAPT Expert
As mentioned in the other ticket, you need to check the filtering settings; this is the most common problem related to the symptoms described.
What distribution were the packages you developed for Linux originally designed for?
The concept of `target_os` evolved somewhat with version 2.0 and then version 2.1.
- WAPT Expert
Thanks for the feedback!
