WAP client update on machines
knpc
Registration: Nov. 20, 2015 - 4:40 p.m.
March 15, 2016 - 3:07 PM
Having upgraded to version 1.3.5, I wanted to update the WAPT client on the machines, but I'm getting an error message on the console.
What do you think?
Thanks
, Knpc
config 5.JPG (244.48 KB) Viewed 5380 times
March 15, 2016 - 5:11 PM
The "update wapt client" function is no longer available since version 1.3.5.
The button has not been removed.
To update your wapt client, you must use the waptupgrade package, which is automatically generated when you create your personal installer. You simply need to apply this package to the machine you want to update.
- Simon
knpc
March 15, 2016 - 6:39 PM
Hi,
I updated from version 1.2.3 to 1.3.5 and I don't see this package.
I see a package called mtt-waptupgrade_1.2.3.2-1496_all.wapt.
Where can I find, download, or create it?
Thanks
March 16, 2016 - 08:41
Hello
, you need to regenerate a custom waptsetup. These steps must be performed from a 1.3.5 console:
http://dev.tranquil.it/scenari/guide_ad ... nsole.html
Note that you do not need to regenerate the private/public keys; you should have already generated these keys previously and need to reuse them.
After generating the custom waptsetup, the package mtt-waptupgrade_1.3.5.0-1496_all.wapt should appear in your repository.
knpc
March 16, 2016 - 2:08 PM
Thank you! Everything works perfectly.
Great product, great forum, and especially a super knowledgeable user.
Thank you all.
PS: I know I'll probably have other questions later. :D
