I have a number of updates to install for a new version of a software program.
The problem is that each version of this software has a new "uninstall key," and if I install it this way, I end up with multiple versions of the software installed simultaneously.
How can I manage this? Is it possible to specify the different "uninstall keys" to Wapt so that it uninstalls itself with each update?
Thank you in advance.
Problem with software update package
- WAPT Expert
Hello, here's
a code example to handle this type of case:
https://www.wapt.fr/fr/doc/wapt-create- ... g-software
