[SOLVED] WAPT creating a Bitwarden package
labile
Registration: February 14, 2022 - 11:48
February 22, 2022 - 10:43
Hello everyone,
In my new role, we use WAPT for software deployment. Being new to this and eager to learn how to use this service, I want to create and install a Bitwarden package.
I found a ready-to-use package in the WAPT Store. However, I want to modify it to use French as the default language, if that's possible with the software. I
also want to modify the configuration to direct the URL server. I found that this is done via the data.json file located in appdate/user/roaming/bitwarden.
I thought about copying this file using the filecopyto function, but it doesn't seem appropriate.
I would appreciate your help with these two points. Thank you in advance for your assistance.
IT Support Technician -
New Wapt User -
Server OS: Debian 10
- Wapt Version: 2.0.0.9450 -
Administration Machine: Windows 10
February 22, 2022 - 9:40 PM
