I get an error message every time I launch pyscripteur stating that "connection to the remote Python engine failed. The remote process console and debugger are not accessible."
I am on enterprise version 2.0.0.9428.
I installed pyscripteur via the package available on the WAPT self-service, version 4.0.
I already have:
- Uninstall/delete the pyscripteur folder in %appdata%/reinstall: same result
- Check that the "Always use sockets" box in the IDE options is checked.
- and check the following lines in pyscripteur.local.ini:
[PythonVersions-x86\Custom Versions]
Path0=Python 3.8 (32bit)=C:\Program Files (x86)\wapt
Count=1
[PythonVersions-x86]
InstallPath=C:\Program Files (x86)\wapt
Does anyone have any ideas?
Mathieu
