Problem executing .VBS script
raigan
Registration: February 28, 2022 - 2:33 PM
February 28, 2022 - 2:56 PM
I'm about to go bald because I can't understand why my script doesn't work in production, even though it works perfectly when I test it directly through PyScripter. Can you shed some light on this?
Here is the Setup.py file.
    print ('Installation de l imprimante')
    with disable_file_system_redirection():
        run('WScript.exe "Install_imp.vbs"')
    print ('Installation terminee')
    print ('Suppression de l imprimante')
        run('WScript.exe "remove_imp.vbs"')
    print ('Suppression terminee')
Thank you very much for your help.
Precision:
- Wapt version 1.8.2 Community edition
- Dedian Linux Server
- OS administration machine: Windows 11
March 3, 2022 - 4:32 PM
Hello Raignan,
when the `install()` script is run through PyScripter, it executes in the user account (which is running PyScripter)
. When a package is deployed, it's done in the LOCAL System account.
In the case of your script, I imagine it connects a printer in the user context. Therefore, when the package is deployed by the service, it will be deployed in the LOCAL System account (and not the current user).
To execute a script in the user's session, you need to use a `session_setup()` function.
Regards,
