Server OS: Debian 10.11
Console OS: Windows Server 2012 R2
WAPT Server Version: 1.8.2
WAPT Agent
Version: 1.7.4.6229 WAPT Setup Version: 1.8.2.7393
WAPT Deploy Version: 1.8.2.7393
Database Status: OK (1.8.2.1)
I'm having trouble migrating my server from version 1.7.4 to 1.8.2 Community.
The procedure runs smoothly as explained here.
However, WAPT Setup (contrary to what the download page says) and WAPT Agent remain at version 1.7.4.
The agent generation, however, completes correctly, indicating that it has been updated in the repositories.
Please help.
Thank you very much.
[SOLVED] Upgrade WAPT Community 1.7.4 to 1.8.2
- WAPT Expert
Hello Flemenier,
could you please check if you have a symbolic link waptsetup-tis.exe -> waptagent.exe in /var/www/wapt?
There was a bug related to this a few years ago.
Regards,
Denis Cardon
Regards,
Denis Cardon
Hello dcardon,
In the rush, I opted for a server migration as explained here.
The backup of the V1.7.4 data to the new 1.8.2 server went smoothly.
Therefore, I can't say whether the symbolic link was present.
Thank you for taking the time to reply.
François Lemeunier.
François Lemeunier.
