[SOLVED] Removing a package from the repository
looplett
Registration: Apr 07, 2022 - 12:57
April 7, 2022 - 1:01 PM
some packages in our server's repository have undergone several iterations, sometimes up to ten.
However, when we try to delete a package and select "Delete from repository," the latest iteration is indeed removed, and the previous iteration appears.
Is it possible to delete all iterations at once, to save ourselves about twenty clicks?
April 7, 2022 - 3:28 PM
Hello bouklett,
you need to uncheck "latest version only" and you will see all the previous versions.
Regards,
