[SOLVED] Procedure for creating a Linux Ubuntu agent
t.heroult
Registration: December 8, 2020 - 10:13 AM
April 12, 2022 - 4:11 PM
Good morning
I'm desperately trying to create a Linux agent, but the procedure in the documentation is broken (even the command...).
wget -O - https://wapt.tranquil.it/$(lsb_release -is)/tiswapt-pub.gpg  | apt-key add -
It's malfunctioning because there's no file https://wapt.tranquil.it/Ubuntu/tiswapt-pub.gpg).
Then, even after trying to tinker with it, nothing worked.
It would be good to have a procedure that works :)
Tom
Consoles: Windows 10 & 11
Infrastructure: Windows
April 12, 2022 - 6:47 PM
Hi Tom,
it's fixed! Thanks for letting us know. :-)
Best regards,
t.heroult
April 13, 2022 - 10:11
Great, I'll test it today and I'll give feedback (positive or negative, depending) :)
t.heroult
April 14, 2022 - 10:28
Well, I can confirm that the procedure is now working.
Just a quick note: when using Ubuntu, you normally can't log in as root via SSH. However, the command
Can only be executed as root, so you need to switch to superuser mode using, for example, the command
sudo bash
Anyway, thank you!
April 15, 2022 - 2:30 PM
Well, for sudo, I was planning to leave that to the discretion of the sysadmin... ;-)
I added it in case someone else has the question :-) (pushed locally internally).
