Hello. When I launch the WAPT console, I get a "repository access error" message. I enter the server's IP address, but I still get an exclamation mark.
Is there anything I need to do to make the console work?
Thank you.
Pb Wapt installation on Windows serv2019
On a fresh installation of WAPT 2.2 on a W2019 VM, I am facing the same problem as adgm11.
The installation completes, but in the "Local WAPT Configuration" when I check the URLs, the main repository URL shows a "Repository access error: 404 Client Error:" and the WAPT server URL shows a "Server access error: 502 Server error:".
DNS has been checked and they are OK.
Could it be that your WAPTNgninx service is paused?
If so, check that the IIS service is not enabled:
Restart the server installation and everything should be OK.
net stop w3svc && net stop was- dcardon
- WAPT Expert
the lack of information isn't very helpful...
WAPT discovery? WAPT Enterprise? See the forum rules.
Do you have the WAPT server interface at http://localhost ?
c:\wapt\wapt-get.exe --version?
`sc query waptserver`?
`sc query waptpostgresql`?
Did you perform the installation with a local admin account or a domain admin account?
Regards,
Regards,
WAPT 2.2 discoverydcardon wrote: ↑Apr 13, 2022 - 2:17 PM WAPT discovery? WAPT Enterprise? See forum rules.
sc query waptserver?
sc query waptpostgresql?
No target
Version: 2.2.1.11899
waptserver and waptpostgresql not installed
domain administrator
Hello, this is the Discovery version. I do have the IIS service installed on my server; I need to uninstall it, is that correct?
What about the WAPTNgninx service? Does it install automatically via the console, or does it need to be done separately?
Thank you.
Thank you.
I invite you to read this section of the documentation on installing the console: https://www.wapt.fr/fr/doc-2.1/wapt-con ... pt-console
