Firefox
rezidu
Registration: March 16, 2015 - 10:21
April 27, 2015 - 3:07 PM
I'm trying to customize my Firefox installation. I've been using the tis-firefox package as a guide.
However, there are a few settings I can't seem to customize (I haven't found these settings in about:config, if they even exist):
- Allow pop-ups (unblock pop-ups) [Options/Content/uncheck "Block pop-up windows"]
- Open PDFs by default with Adobe Reader [Options/Applications]
- Add a URL to the security exceptions [Options/Security/Exceptions...]
If you know how to do this, I'd appreciate it. :D
ssamson
Registration: June 20, 2014 - 10:29
April 27, 2015 - 4:48 PM
Hello rezidu,
For the first question
You can add this
defaultPref("dom.disable_open_during_load", false);
in the mozilla.cfg file
You will have a better chance of success in your search by using English terms such as:
http://lmgtfy.com/?q=firefox+allow+popup+deploy
Feel free to publish your research.
Steven Samson - Tranquil IT Systems
Feel free to leave us your opinion on Wapt in the forum, or to answer our questionnaires :).
