[SOLVED] 7-Zip 23.1 uninstallation error
eliottiph
Registration: May 2, 2022 - 10:41
August 2, 2023 - 3:09 PM
WAPTConsole Enterprise version 2.2.1.11957
Console: Win19 server
SRV: Debian 11
Test machine: Windows 10 22H2
I encountered an error while uninstalling 7zip version 23.1.
The package uninstalls successfully, but gives this error in the console:
Waiting for the removal of key: 7-Zip from Windows registry
[WinError 5] Accès refusé: 'C:\\Program Files\\7-Zip\\7-zip.dll'
  File "shutil.py", line 616, in _rmtree_unsafe
PermissionError: [WinError 5] Accès refusé: 'C:\\Program Files\\7-Zip\\7-zip.dll'
Furthermore, when updating from an older version to this version (23.1), the 7zip right-click menu had disappeared; a forced reinstallation from the console was required to make it reappear.
Eliott
jpele
Registration: March 4, 2019 - 12:01
August 7, 2023 - 3:23 PM
I noticed this bug and identified it as being related to the explorer.exe executable. I don't have a real fix to offer.
Here is the new uninstall() code; you can try uncommenting killalltasks("explorer"), which is hardly recommended...
    # Deleting 7z from path
    remove_from_system_path(app_dir)
    # Removing any remaining files
    if isdir(app_dir):
        # killalltasks("explorer") # can help
        remove_tree(app_dir)
I would appreciate it if you could identify a setting that may have been applied to your 7zip installations that might be causing this problem.
Jimmy
