[RESOLVED] No more VS Code autocompletion when creating a WAPT package
Answer
stan
Registration: May 26, 2025 - 10:16 p.m.
June 18, 2026 - 4:40 PM
I've recently encountered a problem with VS Code when creating my WAPT packages.
When I generate a package template and the folder opens in VS Code, I lose autocompletion. I can't get suggestions for native functions (like print) or setuphelpers.
However, if I open a blank folder, everything works normally.
If anyone can shed some light on this, I'd be very grateful! :D
Thanks in advance.
June 18, 2026 - 6:03 PM
Hi Stan,
what version of Wapt are you using, etc.?
Could you try deleting/renaming the vscode directory in your AppData folder? That often solves the problem. Personally, I don't use vscode; I'm more of an old-school developer with PyScripter3. :-)
Regards,
stan
June 19, 2026 - 09:24
Here is the information:
WAPT Enterprise version 2.6.1.17813
OS Server : Debian 12
OS de la machine d'administration : Windows 11 25H2.
Yes, I've already done that and nothing changes.
For PyScripter3, it's really the last resort if I can't solve the problem with VSCode :)
Stan
stan
June 23, 2026 - 4:03 PM
After downgrading VSCode to version 1.116.0, autocompletion works.
This issue is therefore resolved. :)
Stan
Information:
OS Administration : Windows 11 25H2
WAPT Version : 2.6.1.17813
VSCode Version : 1.116.0
italbot
Registration: Sep 26, 2023 - 3:50 p.m.
June 24, 2026 - 11:39
Noted. After installing version 1.125.0 of VS Code, I still have autocompletion. The problem might be with an extension rather than VS Code itself.
Ingrid
stan
June 24, 2026 - 11:41
I removed everything, I only added the Python extension, the same for 1.116.0 and 1.125.0. And only 1.116 works with autocompletion.
Stan
Information:
June 25, 2026 - 6:01 PM
Hi Stan,
was this related to viewtopic.php?t=4715 ?
Does it now work correctly with the latest version of VS Code?
Regards,
stan
June 25, 2026 - 6:33 PM
I don't think so, I'll try updating VScode tomorrow to see if that changes anything.
Stan
Information:
stan
June 26, 2026 - 12:06
I found the solution. The problem comes from a setting in VS Code, and not from the interpreter or "debugpy".
In the latest versions of VS Code, if GitHub Copilot is enabled, I believe VS Code applies this behavior by default:
JSON
"editor.quickSuggestions": {
    "other": "offWhenInlineCompletions"
This setting disables the standard autocomplete list (Pylance) in favor of Copilot's online suggestions. This is why WAPT functions no longer appear.
To resolve this conflict, you need to force the display of suggestions. I propose adding this default configuration to the settings.json file generated by WAPT:
JSON
    "other": "on"
Here's a short video showing how it works (in the video I use `true` when it should be "on", I think it's already "on" by default, so that's why it worked):
https://youtu.be/I572GGS2ufE
Stan
Information:
Answer
