Agent connection lost
Answer
Kevin-LH76
Registration: February 8, 2026 - 5:57 PM
September 2, 2026 - 11:28
We have a workstation that is no longer communicating with the WAPT server.
I tried reinstalling the agent but it didn't change anything.
I tried the following command:
watp-get register -f
But I'm getting the following error:
C:\Program Files (x86)\wapt> wapt-get register -f
atgtrgse f2026-09-02 11:23:24,742 CRITICAL Unable to build status data for key host_capabilities: ValueError('error parsing asn1 value: ParseError { kind: UnexpectedTag { actual: Tag { value: 0, constructed: false, class: Universal } } }')
Registering host against server: https://wapt.XXXX
FATAL ERROR : error parsing asn1 value: ParseError { kind: UnexpectedTag { actual: Tag { value: 0, constructed: false, class: Universal } } }
The device has communicated with the server in the past; have you encountered this message before?
blemoigne
Registration: July 17, 2020 - 11:29
September 4, 2026 - 3:43 PM
the machine certificates must be corrupted; you should delete them from c:\program files (x86)\wapt\private (pem and crt) and then run the register command again.
Answer
