tis-veyon problem update_package addons
Answer
Mikael S
Registration: January 20, 2025 - 3:54 PM
October 20, 2026 - 1:54 PM
There is a problem with the update_package which now returns the add-on installer instead of the client setup.
Adding line 20 fixes the problem
and not "addons" in to_download["name"]
italbot
Registration: Sep 26, 2023 - 3:50 p.m.
October 20, 2026 - 1:57 PM
Noted, I'll take a look at it, thank you.
Best regards,
Ingrid
freazae
Registration: Oct 23, 2026 - 11:23
October 23, 2026 - 11:25
Will this change be natively integrated into the next package update?
Answer
