How did you deploy your agent?
knpc
Registration: Nov. 20, 2015 - 4:40 p.m.
March 14, 2016 - 11:09 PM
Thanks for the reply.
Regarding the installation of version 1.3.5, do I install it over the existing version or do I need to uninstall everything? It would be more convenient for me to install it over the existing version because I tried installing it directly and encountered problems.
Thanks for your invaluable help,
Knpc.
March 15, 2016 - 11:20
Hello
, yes indeed.
You will find instructions on how to update your Wapt server here (Windows version):
https://dev.tranquil.it/scenari/guide_u ... ndows.html
Simon Fonteneau
knpc
March 15, 2016 - 2:02 PM
Hi,
It now works manually, except that you MUST write the hash entirely in lowercase
I'm starting on the GPO and will get back to you with the result.
Thank you all so much for your help
However, I still get the message at address 127.0.0.1
a.grisard
Registration: March 15, 2016 - 08:14
April 4, 2016 - 10:11
I'm also tearing my hair out trying to install the agent via GPO.
For now I'm testing the command locally, I have:
- Copy waptagent to the root of c:wapt
- retrieved the hash and entered it in the following command:
In the wapt/waptserver/repository/wapt folder, I have:
- waptagent (created via the tools menu)
- waptdeploy
- waptdeploy.version
The contents of waptdeploy.version:
1.3.5
https://serveurwapt/wapt/waptserver/repository/wapt/waptsetup-tis.exe
The contents of my order:
\\serveurwapt\wapt\waptserver\repository\wapt\waptdeploy.exe --hash=f4ac7e3d64887a3ac74d1dc2effa147c87b853d8a4225adde45c694540750a4 --wait=15 --minversion=1.3.5 --waptsetupurl=http://serveurwapt/wapt/waptserver/repository/wapt/waptagent.exe --repo_url=http://serveurwapt/wapt/waptserver/repository/wapt
The .exe file does not appear to be placed in the temporary file, and therefore the HTTP request does not work.
a.grisard
April 5, 2016 - 9:16 AM
I finally managed to deploy my agent locally using a command.
Unfortunately, my GPO isn't working. I set the following parameters (the GPO is correctly deployed to the machine):
Script name: \\serveurad\netlogon\wapt\waptdeploy.exe
Parameters: --hash=be973fac01600641d33239cb45f7863a542f4bb9a0e7d99eed00b6dfedc005f2 --wait=15 --minversion=1.3.5 --repo_url=http://serveurwapt/wapt/
Does anyone have any idea what the problem might be?
SamDaPiRatE
Registration: Apr 27, 2016 - 1:48 p.m.
April 27, 2016 - 2:29 PM
I'm also trying to deploy WaptAgent via GPO, and I'm having trouble...
I think my GPO is correct
. However, I'm unsure where to place waptdeploy.exe.
I put it in this path: \\MYDOMAIN.local\netlogon\waptdeploy.exe.
Where do you place this waptdeploy.exe file?
Thanks
gpo wapt
gpo wapt
April 27, 2016 - 3:14 PM
Have you tried running the command manually?
SamDaPiRatE
April 27, 2016 - 4:04 PM
I tried launching the following command via DOS:
\\domain.local\netlogon\waptdeploy.exe --hash=05d2e30a2db11f803c275f534c6e0235752ff793c8f59b8585634e4e1965fae2 --wait=15 --minversion=1.3.5 --waptsetupurl=http://server.domain.local/wapt/waptagent.exe
It launches successfully, and the agent is installed correctly.
April 27, 2016 - 5:23 PM
First of all, run gpupdate /force and then reboot to verify that the startup script gpo has been enabled.
Otherwise:
Have you tried enabling this GPO?
"Always wait for the network to start up and connect"
The settings:
Computer Configuration\Administrative Templates\System\Logon\ Always wait for the network at computer startup and logon
Then, on the client machine, run the following command:
 gpupdate /force
Then restart the
knpc
April 28, 2016 - 00:01
Hi,
To find the path, I simply used the GPO's browse function and copied the file into the folder that opened. I don't have the URL in my deployment either.
Best regards,
knpc
