Custom Package Creation - FortiClient
admgautier
Registration: Sep 24, 2018 - 4:48 p.m.
April 28, 2022 - 1:44 PM
New to the WAPT field,
I am looking to configure a custom package in order to install the Forticlient_6.4.3.exe software.
I managed to launch the software from the PyScripter console (after modifying the code).
However, I can't figure out what code to add in order to accept the license terms that the software requires me to validate.
Is there some kind of magic code to validate this parameter and thus silently install the software?
Code setup.py:
    # Declaring local variables
    # Installing the software
    print("Installing: %s" % control.package)
    install_exe_if_needed('FortiClientVPNSetup_6.4.3.1608_x64.exe',
        '/s',
        key='',
        min_version=control.get_software_version(),
Thank you in advance for your feedback.
Anthony
Validation license forticlient.png (28.5 KB) Viewed 3464 times
April 28, 2022 - 4:21 PM
The documentation at https://docs.fortinet.com/document/fort ... ng-the-cli mentions an MSI file
. Alternatively, here's a document with an EXE file: https://silentinstallhq.com/forticlient ... -to-guide/
Hope this helps.
admgautier
May 2, 2022 - 09:03
Thank you for your feedback.
I'll test everything and get back to you if it doesn't work.
Best regards,
Anthony
