Signature problem
Jitero
Registration: Apr 14, 2022 - 3:07 p.m.
May 4, 2022 - 11:59
I'm trying to modify a package group on another PC which contains waptsetup.exe and has the same private key as my WAPT server, but I'm getting an error: [error message here].
Do you know what causes it?
Installed WAPT version = 2.2.1
Server OS = Windows Server 2019
Administration/package creation machine OS = Windows 10
May 4, 2022 - 2:33 PM
Based on the error message, it seems the package isn't signed with a recognized key or is incorrectly signed.
I didn't quite understand everything, but:
You mentioned waptsetup.exe on another machine. I think I understand that you installed waptsetup.exe on another machine to access the console (waptagent is sufficient; all machines have the console).
Try reinstalling waptagent.exe instead. It contains the keys you need to verify the package.
Be careful not to create multiple keys, as you risk confusion; reuse your existing keys.
Jitero
May 4, 2022 - 3:20 PM
sfonteneau wrote: ↑May 4, 2022 - 2:33 PM Based on the error message, it seems the package is either not signed with a recognized key or is incorrectly signed.
I used the console via waptagent.exe, but the same error occurs whenever I try to remove a package from a package group. I think I've missed a step; do I need to do something on the server so it recognizes the administrator's machine key?
martiny
Registration: Nov 4, 2021 - 3:45 p.m.
May 5, 2022 - 3:50 PM
Hello Jitero, I encountered a similar problem to yours.
On your WAPT console in C:\Program Files (x86)\wapt\ssl, did you add the .crt certificate?
Jitero
May 6, 2022 - 08:28
martiny wrote: ↑May 5, 2022 - 3:50 PM Hello Jitero, I encountered a similar problem to yours.
Hello Martiny,
In the SSL folder on my machine that I want to make an administrator account, I only have the certificate for my server machine's key
CasseThor
Registration: December 1, 2017 - 9:25 PM
June 22, 2022 - 09:39
Hello
, I have the same problem.
I tried reinstalling with a snapshot in case I'd missed a step, but no luck.
I do have the keys in that folder.
