[RESOLVED] Software does not install on all computers
Alain
Registration: May 16, 2022 - 10:21
May 16, 2022 - 11:39
I have the Wapt Discovery version. I installed my Wapt server on a Windows Server 2019 VM.
I installed the console on my machine. I'm on the same VLAN as the server. I downloaded the Naps2 package, modified my machine, ran the update and installation, and the software installed without any problems on my machine.
However, I installed WaptAgent on a PC (different VLAN). This PC appears correctly in the console, I click "Upgrade" and then "OK," the inventories worked, and I can see everything related to this PC, but when I try to deploy npas2 or other packages, the software doesn't install.
Do you have any ideas?
Thank you.
Alain
May 16, 2022 - 2:37 PM
It's working now. I regenerated the Waptagent and reinstalled the PCs.
