[SOLVED] Wapt discovery then license.
j.bresler
Registration: June 16, 2022 - 11:18
June 17, 2022 - 10:52
I'd like to quickly test and deploy WAPT Discovery.
If I decide to upgrade to the enterprise version later, will I need to reinstall the client on all workstations or just activate a license (or start over on a server with the enterprise version)?
Also, regarding the pricing, €10 excluding VAT per workstation per year, I assume that's per client workstation?
Thank you in advance.
bkolovljanovic
Registration: Apr 20, 2022 - 2:26 p.m.
June 17, 2022 - 11:00
Hello j.bresler,
there's no need to reinstall everything. Simply activating the license will activate the enterprise features.
Yes, it's done via client workstation.
You're welcome, good luck! ;)
vcardon
June 20, 2022 - 11:39
Yes, it is indeed via client workstation.
To be more precise, the license is per agent, because if you deploy WAPT on a server, then it is one license.
