I'd like to quickly test and deploy WAPT Discovery.
If I decide to upgrade to the enterprise version later, will I need to reinstall the client on all workstations or just activate a license (or start over on a server with the enterprise version)?
Also, regarding the pricing, €10 excluding VAT per workstation per year, I assume that's per client workstation?
Thank you in advance.
[SOLVED] Wapt discovery then license.
bkolovljanovic
- Registration: Apr 20, 2022 - 2:26 p.m.
Hello j.bresler,
there's no need to reinstall everything. Simply activating the license will activate the enterprise features.
Yes, it's done via client workstation.
You're welcome, good luck!
