after successfully installing packages on a client, I'd like to specify their installation paths.
Currently, they all install directly to the C: drive, but I'd like them to install to the D: drive. After
consulting numerous articles to understand how to do this, I haven't found any solutions other than
the copytree2() function, which doesn't seem appropriate.
I only know that the modification must be done in setup.py.
Thanks in advance!
[Wapt - installation path]
- WAPT Expert
Good morning
I haven't tried it, but it should normally be okay
When creating a custom Waptagent: First, modify the file:
and modify this line:
https://github.com/tranquilit/WAPT/blob ... up.iss#L31
To replace it with whatever you want.
Then restart the generation of a Waptagent
C:\wapt\waptsetup\waptsetup.isshttps://github.com/tranquilit/WAPT/blob ... up.iss#L31
DefaultDirName="C:\wapt"Then restart the generation of a Waptagent
Thank you for your reply, Simon.
This command installs the agent in D:, but I would like to install the software sent from the WAPT console in D:
and not the agent. For example, when I install Firefox, the files are stored in C:. I would like to change this
behavior and redirect all installations to the D: drive.
Thank you in advance!
- WAPT Expert
Ah yes, okay.
Well, you have two solutions. You need to modify all your WAPT packages to add options:
For example, for Firefox with: `InstallDirectoryPath=d:\firefox\`
https://wiki.mozilla.org/Installer:Comm ... _Arguments
The second solution is to move Program Files:
http://www.clubic.com/forum/microsoft-w ... page1.html
But this only solves the problem for software that installs in Program Files.
- WAPT Expert
You need to modify your WAPT package to change this.
You can use this link for help:
I don't understand; the installation path should be chosen during the "wapt-get make-template *****.exe" command
from an .ini file in which the installation path is specified?
THANKS.
EDIT: I described the case for Firefox, but I have dozens of packages to install on D: (7zip, flash, etc.).
I successfully installed Firefox on D: using the command:
Now, I would like to create a WAPT package for Firefox in which I can specify this .ini file or do anything else
manipulations that would allow me to install the software in D:.
THANKS.
THANKS.
firefox.exe /INI=c:\wapt\firefox.inimanipulations that would allow me to install the software in D:.
THANKS.
- WAPT Expert
Wapt is a command executor, so it cannot control the installation folder location of software.
The technique mentioned is only valid for Firefox. And this type of technique isn't available for all software.
Furthermore, it will require you to modify all the packages in your private repository.
This method will therefore be simpler for you:
But I don't necessarily recommend this method either.
Why do you want to move the software to D:\?
I install my software on D: to keep the system files separate on C: from the software on D:.
I finally found the solution: simply modify the installation command in the setup.py file and specify
an .ini file with the argument /INI=*****.ini:
run(r'firefox.exe /INI=c:\..\..\setup.ini')
Thank you for your help.
I regret to inform you that the method for installing on D: using an .ini file does not work.
Because the installation is performed on a remote machine, the client has no access to the .ini file hosted on the server
and is therefore unable to follow the instructions it contains.
I am therefore looking for a new method to install my software available on WAPT on the
D: drive of client machines.
Thank you.
Thank you.
