[Wapt - installation path]
shirocen
Registration: Apr 25, 2016 - 4:01 p.m.
April 25, 2016 - 4:06 PM
after successfully installing packages on a client, I'd like to specify their installation paths.
Currently, they all install directly to the C: drive, but I'd like them to install to the D: drive. After
consulting numerous articles to understand how to do this, I haven't found any solutions other than
the copytree2() function, which doesn't seem appropriate.
I only know that the modification must be done in setup.py.
Thanks in advance!
April 25, 2016 - 5:57 PM
Good morning
I haven't tried it, but it should normally be okay
When creating a custom Waptagent: First, modify the file:
C:\wapt\waptsetup\waptsetup.iss
and modify this line:
https://github.com/tranquilit/WAPT/blob ... up.iss#L31
DefaultDirName="C:\wapt"
To replace it with whatever you want.
Then restart the generation of a Waptagent
shirocen
April 26, 2016 - 09:12
Thank you for your reply, Simon.
This command installs the agent in D:, but I would like to install the software sent from the WAPT console in D:
and not the agent. For example, when I install Firefox, the files are stored in C:. I would like to change this
behavior and redirect all installations to the D: drive.
Thank you in advance!
April 26, 2016 - 10:38
Ah yes, okay.
Well, you have two solutions. You need to modify all your WAPT packages to add options:
For example, for Firefox with: `InstallDirectoryPath=d:\firefox\`
https://wiki.mozilla.org/Installer:Comm ... _Arguments
The second solution is to move Program Files:
http://www.clubic.com/forum/microsoft-w ... page1.html
But this only solves the problem for software that installs in Program Files.
shirocen
April 26, 2016 - 10:55 AM
Is the line `InstallDirectoryPath=d:\firefox\` correct to add to the setup.py file?
April 26, 2016 - 11:00 AM
You need to modify your WAPT package to change this.
You can use this link for help:
shirocen
April 26, 2016 - 11:13
I don't understand; the installation path should be chosen during the "wapt-get make-template *****.exe" command
from an .ini file in which the installation path is specified?
THANKS.
EDIT: I described the case for Firefox, but I have dozens of packages to install on D: (7zip, flash, etc.).
I successfully installed Firefox on D: using the command:
firefox.exe /INI=c:\wapt\firefox.ini
Now, I would like to create a WAPT package for Firefox in which I can specify this .ini file or do anything else
manipulations that would allow me to install the software in D:.
THANKS.
April 26, 2016 - 12:42
Wapt is a command executor, so it cannot control the installation folder location of software.
The technique mentioned is only valid for Firefox. And this type of technique isn't available for all software.
Furthermore, it will require you to modify all the packages in your private repository.
This method will therefore be simpler for you:
But I don't necessarily recommend this method either.
Why do you want to move the software to D:\?
shirocen
April 27, 2016 - 10:44
I install my software on D: to keep the system files separate on C: from the software on D:.
I finally found the solution: simply modify the installation command in the setup.py file and specify
an .ini file with the argument /INI=*****.ini:
run(r'firefox.exe /INI=c:\..\..\setup.ini')
Thank you for your help.
shirocen
May 13, 2016 - 10:49
I regret to inform you that the method for installing on D: using an .ini file does not work.
Because the installation is performed on a remote machine, the client has no access to the .ini file hosted on the server
and is therefore unable to follow the instructions it contains.
I am therefore looking for a new method to install my software available on WAPT on the
D: drive of client machines.
Thank you.
