Retrieve the UUID of a position
mass
Registration: August 10, 2022 - 10:36
August 10, 2022 - 10:53
I'm having trouble registering workstations on my WAPT server. New workstations being deployed are showing up with the same UUID.
Is it possible to retrieve a workstation's UUID using command prompt or other commands so I can use it in a script?
Thank you.
OS: Linux
Distri: Debian Bullseye
WAPT Discovery
WAPT Server Version: 2.2.1
WAPT Agent Version: 2.2.1.11899
WAPT Setup Version: 2.2.1.11957
WAPT Deploy Version: 2.2.1.11957
August 23, 2022 - 6:48 PM
On a given machine, you can retrieve the UUID that will be used by WAPT by running `sudo apt` as administrator.
wapt-get inventory > c:\out.txt
and by searching for uuid in the out.txt result.
If you have multiple machines with the same UUID, you can use the command
wapt-get generate-uuid
to force a random uuid in the wapt-get.ini file.
