I'm having trouble registering workstations on my WAPT server. New workstations being deployed are showing up with the same UUID.
Is it possible to retrieve a workstation's UUID using command prompt or other commands so I can use it in a script?
Thank you.
Retrieve the UUID of a position
- WAPT Expert
On a given machine, you can retrieve the UUID that will be used by WAPT by running `sudo apt` as administrator.
and by searching for uuid in the out.txt result.
If you have multiple machines with the same UUID, you can use the command to force a random uuid in the wapt-get.ini file.
wapt-get inventory > c:\out.txtIf you have multiple machines with the same UUID, you can use the command
wapt-get generate-uuidSincerely,
