When deploying the OS to a machine via IPXE, a message about certificate verification appears, then nothing else happens.
Is the problem with my certificate?
How can I bypass this issue and continue the OS deployment?
Anthony
[RESOLVED] OS Deployment
admgautier
- Registration: Sep 24, 2018 - 4:48 p.m.
- Attachments
- Error Cert.png (35.11 KiB) Viewed 8650 times
- WAPT Expert
Can you rerun the last command without the "start" so that the error message remains?
admgautier
Thank you for your feedback.
Here is the error message.
I believe I saw in some of your threads that if the ISO file is too large, it can cause this type of malfunction. Is that correct?
- Attachments
- Error Cert-2.png (28.25 KiB) Viewed 8635 times
- WAPT Expert
If you're using a standard Windows 10 ISO, there shouldn't be any problem.
You'd need to check on the server to see if the file actually exists, since it's a 404 error.
admgautier
Okay,
and which directory do I go to to check if the file actually exists on a Linux server?
Sorry, I'm not an expert in this area.
Thanks for your help.
- WAPT Expert
The file must be located at /var/www/wads/iso. The filename is its SHA256 hash.
Do you see the ISO in question referenced in the WAPT console?
Regards,
Regards,
admgautier
Hello Denis,
there's absolutely nothing in the /var/www/wads/iso folder...
Yes, my image was successfully integrated into the WAPT console
- Attachments
- iso console wapt.png (15.74 KB) Viewed 8607 times
- error iso.png (1.89 KiB) Viewed 8607 times
admgautier
After analyzing the logs, I realize (as in a previous thread, viewtopic.php?t=2989&start=20)
that the ISO file size is too large to be imported. However, it does appear in the WAPT console.
How can I modify the size of this body? Specifically, which file on the server should I modify?
Anthony
Anthony
- Attachments
- error iso-log.png (8 KiB) Viewed 8602 times
- WAPT Expert
You can check the `client_max_body_size` in the nginx file.
The ISO must have been modified; the base Microsoft ISO isn't that large.
Regards,
Regards,
admgautier
Found it, it can be configured in the file /etc/nginx/sites-available/wapt.conf (for those who might encounter the same problem).admgautier wrote: ↑Sep 28, 2022 - 4:43 PM After analyzing the logs, I realize (as in a thread viewtopic.php?t=2989&start=20)
How can I modify the size of this body? Or rather, which file on the server should I go to?
Anthony
After restarting the server (because restarting the nginx service is not enough) the iso is downloading.
All that's left is to cross our fingers...
Thank you for your help
- Attachments
- Download iso.png (40.63 KiB) Viewed 8598 times
