run application as Admin
rylo
Registration: Apr 26, 2016 - 10:14
May 2, 2016 - 8:23 PM
I'm currently experimenting with WAPT. I can create packages except for one application;
I know how to install it silently, but only in admin command prompt mode. How can I specify this in the .py file? :?:
If anyone can help, that would be great.
Thanks in advance.
May 3, 2016 - 08:49
Normally, all of this is handled automatically.
If the installation is launched from the console, it will be done using the system account.
Therefore, the installer will have full privileges.
If the installation is done via the command line (wapt-get install tis-monsoft), and the user is not an administrator, a username and password will be required to access the Wapt service, which uses the system account.
rylo
May 3, 2016 - 10:28
Thank you for this answer, if that's it I don't see here is the log
installing qlikview
2016-04-29 11:28:21,420 CRITICAL Fatal error in install script: CalledProcessError: Command '('"QlikViewDesktop_x64Setup.exe" /S /v/qn',)' returned non-zero exit status 1619:
File "C:\wapt\common.py", line 3178, in install_wapt
File "c:\windows\temp\waptkaqffm\setup.py", line 8, in install
run(r'"QlikViewDesktop_x64Setup.exe" /S /v/qn')
File "C:\wapt\common.py", line 3025, in run
return setuphelpers.run(*arg,pidlist=self.pidlist,**args)
File "C:\wapt\setuphelpers.py", line 1020, in run
raise subprocess.CalledProcessError(proc.returncode,cmd,''.join(output))
2016-04-29 11:28:21,467 CRITICAL Package qlikview (=11.0.11414.0-0) not installed due to errors: CalledProcessError: Command '('"QlikViewDesktop_x64Setup.exe" /S /v/qn',)' returned non-zero exit status 1619
2016-04-29 11:28:21,467 CRITICAL Exception: Error during install of qlikview (=11.0.11414.0-0): errors in packages qlikview
2016-04-29 11:28:23,217 ERROR Traceback (most recent call last):
File "C:\wapt\lib\site-packages\rocket\main.py", line 143, in start
time.sleep(THREAD_STOP_CHECK_INTERVAL)
IOError: [Errno 4] Interrupted function call
May 3, 2016 - 10:41
This is error 1619 (Windows error)
Does it work when you run your command as administrator?
rylo
May 3, 2016 - 10:44
Yes, running cmd as admin works perfectly, hence my question about admin rights.
Even when I use runas it works, I don't understand. :?: :!:
May 3, 2016 - 2:26 PM
It is possible that your application does not support installation under a system account
You can make a
with an administrator account (right-click on cmd, run as administrator)
If the installation works via the command line, that would explain the problem
rylo
May 3, 2016 - 3:39 PM
Yes, that works, well, I'll have to find an alternative
May 3, 2016 - 3:48 PM
so37
Registration: Apr 10, 2016 - 1:43 p.m.
May 3, 2016 - 4:04 PM
Is there a way to ensure that a domain admin launches the installation and not the system in WaptConsole?
rylo
May 3, 2016 - 4:37 PM
Thanks for the link, but I had already looked at that information without success.
I solved my problem using Fog, which manages application deployment.
Thanks again for your help.
