May 3, 2016 - 10:28
Thank you for this answer, if that's it I don't see here is the log
installing qlikview
2016-04-29 11:28:21,420 CRITICAL Fatal error in install script: CalledProcessError: Command '('"QlikViewDesktop_x64Setup.exe" /S /v/qn',)' returned non-zero exit status 1619:
File "C:\wapt\common.py", line 3178, in install_wapt
File "c:\windows\temp\waptkaqffm\setup.py", line 8, in install
run(r'"QlikViewDesktop_x64Setup.exe" /S /v/qn')
File "C:\wapt\common.py", line 3025, in run
return setuphelpers.run(*arg,pidlist=self.pidlist,**args)
File "C:\wapt\setuphelpers.py", line 1020, in run
raise subprocess.CalledProcessError(proc.returncode,cmd,''.join(output))
2016-04-29 11:28:21,467 CRITICAL Package qlikview (=11.0.11414.0-0) not installed due to errors: CalledProcessError: Command '('"QlikViewDesktop_x64Setup.exe" /S /v/qn',)' returned non-zero exit status 1619
2016-04-29 11:28:21,467 CRITICAL Exception: Error during install of qlikview (=11.0.11414.0-0): errors in packages qlikview
2016-04-29 11:28:23,217 ERROR Traceback (most recent call last):
File "C:\wapt\lib\site-packages\rocket\main.py", line 143, in start
time.sleep(THREAD_STOP_CHECK_INTERVAL)
IOError: [Errno 4] Interrupted function call
