When I add the adobereader package from the Tranquil'IT repository to my package group, I get the error "Missing dependencies" (see attached image).
If I add the package to the self-service package manager, the self-service package updates, but the adobereader package is still not available on the user's machine.
Do you know what might be causing this?
Thank you.
Gauthier.
- WAPT version installed: 2.1.2
- Server OS: Debian Buster
[SOLVED] Missing dependencies error
gauthier_leclercq
- Registration: Sep 21, 2018 - 11:43
- Attachments
- wapterror.png (8.2 KB) Viewed 12476 times
- WAPT Expert
If you do have an adv-adobereader package in your repository, you should check its compatibility with your machine's capabilities (maturity, language, architecture (32-bit vs. 64-bit), etc.). A fairly common problem is having a 32-bit Windows machine and only having a 64-bit package.
Regards,
Regards,
benoitpatin
- Registration: February 21, 2018 - 5:05 PM
Hi Denis,
We don't have 32-bit Windows here.
Any other ideas?
Thanks
Any other ideas?
Thanks
- WAPT Expert
Is the downloaded package the 64-bit package for Windows? Is the agent up to date? Is it properly imported into production (or at the correct maturity level)?
We're going to implement a graphical method to determine why a package matches or doesn't match on a given machine. But for now, we need to check the different capabilities individually.
gauthier_leclercq
Yes, I confirm the machine is a 64-bit machine.
Is the downloaded package the 64-bit package for Windows? Yes, Arch in All (see attached image).
Is the agent up to date? Yes, version 2.1.2.10652.
Is it properly imported into production (or at the correct maturity level)? Yes, imported into production.
Gauthier.
Gauthier.
- Attachments
- adobereader.png (5.42 KB) Viewed 12432 times
- WAPT Expert
Were you able to resolve the capacity matching issue?
Regards,
Regards,
- WAPT Expert
Okay, thanks for the feedback, Stany! I'm marking this as resolved.
