I'm having trouble upgrading WAPT from 2.2 to 2.3. Since my original installation is on a different partition than C:, it's not offering me the upgrade option, but a fresh installation.
Do you have a solution to this problem?
Thank you,
Dorian
Problem upgrading from 2.2 to 2.3 (Windows)
- WAPT Expert
the innosetup installer (which is used to package the WAPT installer on Windows) should find the existing installation (unless the corresponding registry entries have been deleted). We don't recommend installing the server on a drive other than C:\, but it should still work.
Did you correctly select waptserversetup.exe and not waptsetup.exe during your upgrade?
Regards,
Regards,
InfoPerverie
- Registration: January 11, 2023 - 3:48 PM
thank you for your reply.
Could you please provide the path to the relevant registry keys so I can take a look? I have the correct installer, but it's not detecting the installation.
Thank you
. Best regards.
Thank you
. Best regards.
- WAPT Expert
Computer\HKEY_LOCAL_MACHINE\SOFTWARE\WOW6432Node\Microsoft\Windows\CurrentVersion\Uninstall\WAPT Server_is1Denis
InfoPerverie
The specified paths are correct, yet it doesn't detect the installation.
Furthermore, I don't think it's very clean to install it on C:\; if Wapt starts to fill up my partition, my server will malfunction.
