[SOLVED] wapt agent and repo_rules
guigeek
Registration: Nov 21, 2017 - 9:21 p.m.
March 2, 2023 - 4:58 PM
I'm setting up secondary repositories on all sites.
Everything works with the secondary repositories themselves.
However, in the agent configuration, `use_repo_rules` is always set to `false`.
I've regenerated the agent several times, checking the "Use repository access rules" option, but it doesn't change anything.
Have I missed something?
Thanks!
PS: I'm on version 2.3 on a Debian Buster server.
jdziadek
Registration: January 23, 2023 - 4:10 PM
March 3, 2023 - 09:11
Hello, if I'm not mistaken, the agent configuration will only apply to future installations. If you want to modify existing installations, you need to edit the wapt-conf-policy package.
Debian 11
WAPT Version: 2.4.0.14143
guigeek
March 3, 2023 - 09:16
Yes, but I pushed the waptupgrade package to all machines and it didn't change the use_repo_rules variable :(
jdziadek
March 3, 2023 - 09:18
guigeek wrote: ↑March 3, 2023 - 9:16 AM Yes, but I pushed the waptupgrade package to all machines and it didn't change the use_repo_rules variable. :(
It's not the waptupgrade, it's the "tis-wapt-conf-policy" package
Debian 11
March 3, 2023 - 11:46
could you please specify whether you are using the enterprise version of wapt (licensed version), or the discovery version?
guigeek
March 3, 2023 - 2:44 PM
In the enterprise version, but indeed, by retrieving the wapt-conf-policy package and adapting it for my needs, I was able to set the use_repo_rules variable to False everywhere.
Now I don't understand why my agents are finding 0 available packages on the remote repositories even though the rules are configured and synchronization is complete. ;)
jdziadek
March 6, 2023 - 12:48
guigeek wrote: ↑March 3, 2023 - 2:44 PM in the enterprise version, but indeed, by retrieving the wapt-conf-policy package and adapting it for my needs, I was able to set the use_repo_rules variable to False everywhere.
Now I don't understand why my agents are finding 0 available packages on the remote repositories even though the rules are configured and the synchronization is also in place. ;)
I don't know if this will help, but I had a problem with my rules.
For example, if I used the IP address 192.168.0.1/13 to retrieve all IP addresses in the 192.168.XX range, it didn't work, but using 192.168.0.0/13 worked immediately.
Debian 11
March 6, 2023 - 12:52
jdziadek wrote: ↑March 6, 2023 - 12:48
That's normal then: https://mxtoolbox.com/subnetcalculator.aspx
for 192.168.0.1/13 192.168.0.1 is not valid
March 6, 2023 - 12:56
In the agent's repository tab, is the correct repository appearing?
guigeek
March 6, 2023 - 8:27 PM
Yes, it's definitely the right repo!
And in the tasks, we can clearly see that it's searching the correct repo and finding a significant number of packages to examine... but it doesn't see any packages to update, even though there are some!
