Removing icons from the desktop
jm_grosse
Registration: February 10, 2023 - 10:22
May 24, 2023 - 3:24 PM
I'm trying to remove the Google Chrome icon from users' desktops.
I created a package for this and I'm using the command:
`def install():
remove_desktop_shortcut('Google Chrome')`.
I don't get an error message, but the shortcut is still there.
Thank you for your help.
May 24, 2023 - 9:49 PM
Is the shortcut on the user's desktop or on the "All Users" desktop? If it's on the user's desktop, you also need to run `session_setup`
def session_setup():
    remove_user_desktop_shortcut('Google Chrome')
jm_grosse
May 25, 2023 - 1:54 PM
Despite adding this second command, the icon still does not disappear.
May 25, 2023 - 2:00 PM
You can execute the following command:
wapt-get session-setup nom du paquet  -f
in the user session to see?
jm_grosse
May 25, 2023 - 3:57 PM
Here's the result:
`wapt-get session-setup srv_truc-icone_visio -f`
Configuring srv_truc-icone_visio ...
Running session_setup for package srv_truc-icone_visio(=0-0) and user paul.ochon
Done
and the icon is still there
May 25, 2023 - 5:22 PM
The icon is in:
C:\Users\Public\Desktop
Or
C:\Users\username\Desktop
jm_grosse
May 26, 2023 - 08:32
It is located in c:\users\public\desktop
May 26, 2023 - 11:15
C:\\Users\\Public\\Desktop\\Google\xa0Chrome.lnk
I just noticed that the Chrome space is a non-breaking space
Therefore, we must use...:
remove_desktop_shortcut('Google\xa0Chrome')
I don't know why they did that...
How I managed to see it:
print(glob.glob('C:\\Users\\Public\\Desktop\\' + '*.lnk'))
jm_grosse
May 26, 2023 - 1:51 PM
Great, it worked.
Thank you
