I'm trying to remove the Google Chrome icon from users' desktops.
I created a package for this and I'm using the command:
`def install():
remove_desktop_shortcut('Google Chrome')`.
I don't get an error message, but the shortcut is still there.
Thank you for your help.
Removing icons from the desktop
- WAPT Expert
Is the shortcut on the user's desktop or on the "All Users" desktop? If it's on the user's desktop, you also need to run `session_setup`
def session_setup():
remove_user_desktop_shortcut('Google Chrome')
- WAPT Expert
You can execute the following command:
in the user session to see?
wapt-get session-setup nom du paquet -fHere's the result:
`wapt-get session-setup srv_truc-icone_visio -f`
Configuring srv_truc-icone_visio ...
Running session_setup for package srv_truc-icone_visio(=0-0) and user paul.ochon
Done
and the icon is still there
Done
- WAPT Expert
The icon is in:
Or
C:\Users\Public\DesktopCode: Select all
C:\Users\username\Desktop- sfonteneau
- WAPT Expert
C:\\Users\\Public\\Desktop\\Google\xa0Chrome.lnkTherefore, we must use...:
remove_desktop_shortcut('Google\xa0Chrome')
I don't know why they did that...
How I managed to see it:
print(glob.glob('C:\\Users\\Public\\Desktop\\' + '*.lnk'))
