I have a piece of software that installs correctly and enters the silent uninstallation key, but the return code is not 0.
What are the best practices for this type of problem?
Thank you in advance,
Thierry Rapp
[SOLVED] Handling return code for uninstall
- WAPT Expert
Good morning
In this case, I advise you to clear uninstallkey after the installation:
SO :
This way wapt will forget the key
then create an uninstall function:
SO :
uninstallkey = []then create an uninstall function:
run('uninstall.exe',accept_returncodes=2)
Thierry Rapp
- Registration: Apr 04, 2023 - 08:03
I tested it:
The Uninstall method executed directly works
The remove me method returns another error
app_uninstall_key = '{7261A53C-9352-45D1-8DE0-B326E177CA84}'
# Declaring local variables
fichier_lic=makepath('c:','ProgramData','itech','CESAR-LCPC','6.3','CDs')
fichier_nethasp=makepath('c:','CESAR-LCPCv2022.0','bin')
rep_syswow=makepath('c:','Windows','SysWOW64')
# Installing the software
print("Installing: CESAR-LCPCv2022.0.2.exe")
install_exe_if_needed('CESAR-LCPCv2022.0.2.exe',
silentflags='/b0 /q2',
key=app_uninstall_key,
min_version='2022.0',
timeout=600,
accept_returncodes=[0,12]
if not isdir(fichier_lic):
mkdirs(fichier_lic)
filecopyto('CESAR-LCPC_V6.3.ilicx',fichier_lic)
filecopyto('nethasp.ini',fichier_nethasp)
filecopyto('nethasp.ini',rep_syswow)
uninstallkey =[]
uninstCMD = uninstall_cmd(app_uninstall_key)
print(uninstCMD)
run(uninstCMD,accept_returncodes=[0,12])
wait_uninstallkey_present()
- WAPT Expert
Can you provide the error message?
I have a doubt about something...
Can you declare uninstallkey right before setup.py?
I don't think that's it, but... if uninstallkey is empty, then wapt no longer has a key to test. If it continues to give errors, it means the key is still there
uninstallkey =[]
timeout=600,
mkdirs(fichier_lic)
uninstallkey =[]
print(uninstCMD)
- WAPT Expert
Oh yes, be careful when you're doing your tests; you absolutely must reinstall the program before testing a remove command, otherwise it won't work because the code isn't in the database! That might be the simple reason
Thierry Rapp
Removing C:\waptdev\insastg-cesar_2022.0.2-2_windows_PROD ...
2023-06-09 07:39:07,072 CRITICAL Critical error during uninstall: CalledProcessErrorOutput: Command 'C:\\PROGRA~3\\UNINST~1\\{7261A~1\\Setup.exe /remove /q' returned non-zero exit status 12.
Output:
No package removed !
FATAL ERROR : TypeError: not all arguments converted during string formatting-
Thierry Rapp
I'm restarting the installation.
The program is uninstalled correctly; it's just triggering an exception.
Thierry Rapp
Une exception s'est produite : SystemExit (note: full exception trace is shown but execution is paused at: _run_module_as_main)
3
File "C:\Program Files (x86)\wapt\wapt-get.py", line 817, in main
print("=== Error removing packages ===\n%s" % "\n".join([" %s" % p for p in errors]))
File "C:\Program Files (x86)\wapt\wapt-get.py", line 817, in <listcomp>
File "C:\Program Files (x86)\wapt\wapt-get.py", line 1651, in main
sys.exit(3)
File "C:\Program Files (x86)\wapt\wapt-get.py", line 1677, in <module>
main()
File "C:\Program Files (x86)\wapt\Lib\site-packages\runpy.py", line 87, in _run_code
File "C:\Program Files (x86)\wapt\Lib\site-packages\runpy.py", line 194, in _run_module_as_main (Current frame)
SystemExit: 3- dcardon
- WAPT Expert
Thank you for your feedback Thierry, we have made a fix for the exception message, it will be included in the next release 2.4.Thierry Rapp wrote: ↑June 9, 2023 - 08:43Code: Select all
Une exception s'est produite : SystemExit (note: full exception trace is shown but execution is paused at: _run_module_as_main) 3 File "C:\Program Files (x86)\wapt\wapt-get.py", line 817, in main print("=== Error removing packages ===\n%s" % "\n".join([" %s" % p for p in errors])) File "C:\Program Files (x86)\wapt\wapt-get.py", line 817, in <listcomp> print("=== Error removing packages ===\n%s" % "\n".join([" %s" % p for p in errors])) TypeError: not all arguments converted during string formatting During handling of the above exception, another exception occurred: File "C:\Program Files (x86)\wapt\wapt-get.py", line 1651, in main sys.exit(3) File "C:\Program Files (x86)\wapt\wapt-get.py", line 1677, in <module> main() File "C:\Program Files (x86)\wapt\Lib\site-packages\runpy.py", line 87, in _run_code File "C:\Program Files (x86)\wapt\Lib\site-packages\runpy.py", line 194, in _run_module_as_main (Current frame) SystemExit: 3
I'm marking the topic as [RESOLVED].
