[SOLVED] Handling return code for uninstall
Thierry Rapp
Registration: Apr 04, 2023 - 08:03
June 8, 2023 - 09:45
I have a piece of software that installs correctly and enters the silent uninstallation key, but the return code is not 0.
What are the best practices for this type of problem?
Thank you in advance,
Thierry Rapp
June 8, 2023 - 10:15
Good morning
In this case, I advise you to clear uninstallkey after the installation:
SO :
This way wapt will forget the key
then create an uninstall function:
    run('uninstall.exe',accept_returncodes=2)
Thierry Rapp
June 8, 2023 - 10:50
I tested it:
The Uninstall method executed directly works
The remove me method returns another error
app_uninstall_key = '{7261A53C-9352-45D1-8DE0-B326E177CA84}'
    # Declaring local variables
    fichier_lic=makepath('c:','ProgramData','itech','CESAR-LCPC','6.3','CDs')
    fichier_nethasp=makepath('c:','CESAR-LCPCv2022.0','bin')
    rep_syswow=makepath('c:','Windows','SysWOW64')
    # Installing the software
    print("Installing: CESAR-LCPCv2022.0.2.exe")
    install_exe_if_needed('CESAR-LCPCv2022.0.2.exe',
        silentflags='/b0 /q2',
        key=app_uninstall_key,
        min_version='2022.0',
        timeout=600,
        accept_returncodes=[0,12]
    if not isdir(fichier_lic):
        mkdirs(fichier_lic)
    filecopyto('CESAR-LCPC_V6.3.ilicx',fichier_lic)
    filecopyto('nethasp.ini',fichier_nethasp)
    filecopyto('nethasp.ini',rep_syswow)
    uninstallkey =[]
    uninstCMD = uninstall_cmd(app_uninstall_key)
    print(uninstCMD)
    run(uninstCMD,accept_returncodes=[0,12])
    wait_uninstallkey_present()
June 8, 2023 - 12:08
Can you provide the error message?
I have a doubt about something...
Can you declare uninstallkey right before setup.py?
uninstallkey =[]
        timeout=600,
        mkdirs(fichier_lic)
    uninstallkey =[]
    print(uninstCMD)
I don't think that's it, but... if uninstallkey is empty, then wapt no longer has a key to test. If it continues to give errors, it means the key is still there
June 8, 2023 - 12:18
Oh yes, be careful when you're doing your tests; you absolutely must reinstall the program before testing a remove command, otherwise it won't work because the code isn't in the database! That might be the simple reason
Thierry Rapp
June 9, 2023 - 07:42
Removing C:\waptdev\insastg-cesar_2022.0.2-2_windows_PROD ...
2023-06-09 07:39:07,072 CRITICAL Critical error during uninstall: CalledProcessErrorOutput: Command 'C:\\PROGRA~3\\UNINST~1\\{7261A~1\\Setup.exe /remove /q' returned non-zero exit status 12.
Output:
No package removed !
FATAL ERROR : TypeError: not all arguments converted during string formatting
Thierry Rapp
June 9, 2023 - 07:46
I'm restarting the installation.
The program is uninstalled correctly; it's just triggering an exception.
Thierry Rapp
June 9, 2023 - 08:43
Une exception s'est produite : SystemExit       (note: full exception trace is shown but execution is paused at: _run_module_as_main)
3
  File "C:\Program Files (x86)\wapt\wapt-get.py", line 817, in main
    print("=== Error removing packages ===\n%s" % "\n".join(["  %s" % p for p in errors]))
  File "C:\Program Files (x86)\wapt\wapt-get.py", line 817, in <listcomp>
  File "C:\Program Files (x86)\wapt\wapt-get.py", line 1651, in main
    sys.exit(3)
  File "C:\Program Files (x86)\wapt\wapt-get.py", line 1677, in <module>
    main()
  File "C:\Program Files (x86)\wapt\Lib\site-packages\runpy.py", line 87, in _run_code
  File "C:\Program Files (x86)\wapt\Lib\site-packages\runpy.py", line 194, in _run_module_as_main (Current frame)
SystemExit: 3
June 13, 2023 - 12:48
Thierry Rapp wrote: ↑June 9, 2023 - 08:43
3
    sys.exit(3)
    main()
SystemExit: 3
Thank you for your feedback Thierry, we have made a fix for the exception message, it will be included in the next release 2.4.
I'm marking the topic as [RESOLVED].
