[SOLVED] WADS - ISO upload error
erems
Registration: Apr 25, 2023 - 3:52 p.m.
July 10, 2023 - 3:57 PM
FYI, this thread is very similar to this one, which is resolved but without a description of the solution: viewtopic.php?t=3335
Uploading an ISO image to WADS consistently fails. The hash calculation is successful, then the upload begins:
You can clearly see the ISO file being uploaded to /var/www/wads/iso/
then it stops with an error:
Ultimately, the image in "/var/www/wads/iso" is incomplete (approximately 2GB instead of the normal 5GB)
In /var/log/waptserver.log:
[waptserver ] CRITICAL upload deploy files (dd5082f658887ac012dd5532834e9d2bf4e57829dfc6d2a2f1ec328ecfe91bf2.iso) failed Exception('File already exists')
There is no CPU/memory saturation during the operation. Nor is there disk saturation.
- Ubuntu 20.04 server with WAPT 2.3
- In the Nginx wapt.conf configuration file:
client_max_body_size 12288m;
client_body_timeout 5800;
Thank you for your help.
July 10, 2023 - 4:29 PM
Hello
, I see you're on version 2.3.
Could you upgrade to 2.4? Fixes have been released for this issue.
erems
July 11, 2023 - 08:24
unfortunately, the upgrade to version 2.4 broke our Active Directory connection. We had to revert to the previous version for now, while we wait to upgrade Samba.
Is there a workaround for version 2.3?
Regards.
July 13, 2023 - 1:53 PM
Try adding `
proxy_request_buffering off;`
to your Nginx configuration.
It's one of the changes that was made in Wapt version 2.4.
Otherwise, Tranquilit also uses Samba... ;)
erems
July 18, 2023 - 08:55
I tried disabling "proxy_request_buffering" but it wasn't enough.
It's not a big deal for now; we'll wait until we can upgrade to WAPT 2.4.
Best regards.
July 21, 2023 - 1:53 PM
thank you for your feedback, I'm marking the topic as resolved.
Regards,
