Error message when trying to connect to WAPTconsole
Answer
alexandre.vasseur
Registration: Nov 21, 2023 - 09:48
November 21, 2023 - 10:08 AM
I'm having trouble connecting to WaptConsole. I have the message attached. Does anyone have any ideas?
November 21, 2023 - 10:20
to help you more precisely I would need the server's Windows/Linux operating system and its version to give you the correct commands
(see forum rules)
. Simon
alexandre.vasseur
November 21, 2023 - 10:55 AM
my server's operating system and version is Debian 10
November 21, 2023 - 12:28
Try restarting the wapt server:
`systemctl restart waptserver`.
You can then check if the service has started correctly:
`systemctl status waptserver`.
alexandre.vasseur
November 21, 2023 - 2:01 PM
Thank you for your feedback. I just tried the steps you suggested, but the restart doesn't seem to work. So I tried a start instead, and when I check the status, it shows as enabled, but then it reverts to failed, as shown in the attached image.
Also, on the console, I'm getting another error message during login: 502 Bad Gateway
November 21, 2023 - 3:08 PM
Is the disk space okay?
df -h
Is postgres started?
systemctl status postgresql
alexandre.vasseur
November 21, 2023 - 3:14 PM
It was the PostgreSQL server... I followed the same steps as with WaptServer and everything is working again. Thank you so much for your help.
Have a good afternoon.
Answer
