[SOLVED] Installing WAPT Agent on macOS El Capitan
YohanRodriguez
Registration: December 1, 2023 - 2:26 PM
December 1, 2023 - 2:37 PM
I am trying to install the WAPT agent on an older version of macOS (El Capitan 10.11.6)
Here is the message I get in the console:
$ sudo wapt-get register
dyld: lazy symbol binding failed: Symbol not found: _getentropy
Referenced from: /opt/wapt/lib/libpython3.8.dylib
Expected in: /usr/lib/libSystem.B.dylib
dyld: Symbol not found: _getentropy
Thank you in advance if you have any leads.
December 1, 2023 - 3:56 PM
Hi Yohan,
the WAPT agent for macOS is only available from Mojave (macOS 10.14) onwards. You should look into upgrading your OS.
Note: even if your machine doesn't officially support newer versions of macOS, you can try upgrading using https://dortania.github.io/OpenCore-Pos ... pdate.html
YohanRodriguez
December 4, 2023 - 9:43 AM
dcardon wrote: Dec 1, 2023 - 3:56 PM Hello Yohan,
the WAPT agent on macOS is only available from Mojave (macOS 10.14) onwards. You should look into upgrading the OS.
Note: even if the machine doesn't officially support newer versions of macOS, you can try an upgrade with https://dortania.github.io/OpenCore-Pos ... pdate.html
Hello Denis,
Thank you for the feedback.
This machine was a test machine, I'll check on our network if the other Macs are newer and up-to-date.
I'll get back to you if needed.
Yohan.
December 4, 2023 - 3:16 PM
Hi Yohan,
thanks for your feedback. As I mentioned earlier, you can follow the GitHub page linked in my previous post to install a more recent version of macOS on your machine. I don't know how it performs in everyday use, but I've seen that it works quite well on a test machine.
Best regards,
