[RESOLVED] Error creating waptagent.exe (after upgrade)
Marceld
Registration: March 22, 2023 - 1:19 PM
February 14, 2024 - 09:27
We are still experiencing the same issue today as with the following ticket: viewtopic.php?p=13388#p13388
We were initially at version 2.4.0.14143.
The error is as follows:
We tried generating the package via the console but we get the following error (toto is only used for capture, the console user gives us the same error):
We have been without WAPT since Monday, and our list of vulnerabilities is growing quite rapidly :D
Good day
Thanks in advance
Marceld
February 14, 2024 - 09:47
Ah, to clarify:
- We performed the upgrade on Monday. Perhaps we need to force a certificate update in this case?
Thanks
Marceld
February 14, 2024 - 5:00 PM
Update:
We just tried to upgrade to "2.5.4.15335" but we now get this message when generating the WAPT package:
Our admin PC is indeed running "2.5.4.15335" installed manually.
Here are the server versions:
THANKS
Marceld
February 14, 2024 - 5:07 PM
Update X:
If I try to generate the package via the console, here's what I get:
February 15, 2024 - 09:42
we've released a new version, 2.5.4.15337 (01a4eee0).
It should resolve your issue,
Simon.
February 15, 2024 - 4:09 PM
Hello Marcel,
is the problem resolved?
Regards,
Marceld
February 15, 2024 - 5:24 PM
dcardon wrote: ↑Feb 15, 2024 - 4:09 PM Hello Marceld,
Regards,
Good evening,
Yes, thank you very much. Everything works with this version. I do have a couple of minor things to reconfigure, but I'll create a new thread if needed
- Loss of SSO for the application center
- The self-service system no longer seems to match the application center; on the user side, they no longer see any applications.
Thank you again
Good evening
