[SOLVED] Error creating a desktop shortcut for a user
Guillaume_I
Registration: March 15, 2024 - 4:34 PM
March 18, 2024 - 1:43 PM
I want to create a shortcut for the Wapt console:
I'm following the documentation: 2.1.3.5. Create a desktop shortcut for a logged-in user
(I've noted that I need to use the setup_session function, but I don't understand how to use it... I'm starting from -1 in Python)
    create_user_desktop_shortcut(r'WAPT Console Management', target='C://Program Files (x86)//wapt//waptconsole.exe')
It works perfectly with Pyscripter (I tried with different paths: c:\pro.., c:/pro...)
But via the wapt console, I get the following error:
  File "C:\Program Files (x86)\wapt\common.py", line 4234, in install_wapt
  File "C:\WINDOWS\TEMP\wapt8x3n6idv\setup.py", line 5, in install
  File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 3993, in create_user_desktop_shortcut
    sc_path = os.path.join(desktop(0), label)
  File "C:\Program Files (x86)\wapt\lib\site-packages\winshell.py", line 159, in desktop
    return get_path ((shellcon.CSIDL_DESKTOP, shellcon.CSIDL_COMMON_DESKTOPDIRECTORY)[common])
  File "C:\Program Files (x86)\wapt\lib\site-packages\winshell.py", line 140, in get_path
    return shell.SHGetFolderPath (0, folder_id, None, 0)
pywintypes.com_error: (-2147024894, 'Le fichier spécifié est introuvable.', None, None)
0x80070002 : Le fichier spécifié est introuvable
If anyone has any leads, thank you in advance.
Installed WAPT version (2.5.4.15342)
- Server OS (Debian 12)
- Operating system of the administration/package creation machine (Windows 10 - 22H2)
Environment information:
WAPT Server OS version: Debian 12;
WAPT version: 2.6.0.16937 (Enterprise Edition);
OS of the machine from which the packages are created: Windows 10 22H2;
Secondary repository: Ubuntu 22.04
March 18, 2024 - 1:56 PM
Good morning
You should not use `create_user_desktop_shortcut` in the `install` function, but rather `create_desktop_shortcut`
Utilisable en session_setup() (bureau de l’utilisateur)
Utilisable dans fonction install()   (all users)
Guillaume_I
March 18, 2024 - 2:09 PM
Yes, it works, thank you for the reply.
However, if I want to use create_user_desktop_shortcut, it seems I'm making a mistake again:
def session_setup():
The error in the console is:
AttributeError: module '__waptsetup_ng97cnyb6o__' has no attribute 'install'
Can you tell me what's wrong?
March 18, 2024 - 4:45 PM
Hello Guillaume,
There must be a `def install()` function in `setup.py`. You can add a simple `pass` to the `setup.py` file if there is only a `session_setup()` function
    pass
Guillaume_I
March 25, 2024 - 2:08 PM
Hello Denis,
thank you for your feedback.
I had initial training at the end of last week, and these points are clearer to me now.
Guillaume Leduc.
March 29, 2024 - 10:42
Thanks for the feedback, Guillaume. :-)
Have a good weekend and a happy Easter,
Denis.
