I want to create a shortcut for the Wapt console:
I'm following the documentation: 2.1.3.5. Create a desktop shortcut for a logged-in user
(I've noted that I need to use the setup_session function, but I don't understand how to use it... I'm starting from -1 in Python)
create_user_desktop_shortcut(r'WAPT Console Management', target='C://Program Files (x86)//wapt//waptconsole.exe')But via the wapt console, I get the following error:
File "C:\Program Files (x86)\wapt\common.py", line 4234, in install_wapt
File "C:\WINDOWS\TEMP\wapt8x3n6idv\setup.py", line 5, in install
File "C:\Program Files (x86)\wapt\setuphelpers_windows.py", line 3993, in create_user_desktop_shortcut
sc_path = os.path.join(desktop(0), label)
File "C:\Program Files (x86)\wapt\lib\site-packages\winshell.py", line 159, in desktop
return get_path ((shellcon.CSIDL_DESKTOP, shellcon.CSIDL_COMMON_DESKTOPDIRECTORY)[common])
File "C:\Program Files (x86)\wapt\lib\site-packages\winshell.py", line 140, in get_path
return shell.SHGetFolderPath (0, folder_id, None, 0)
pywintypes.com_error: (-2147024894, 'Le fichier spécifié est introuvable.', None, None)
0x80070002 : Le fichier spécifié est introuvableInstalled WAPT version (2.5.4.15342)
- Server OS (Debian 12)
- Operating system of the administration/package creation machine (Windows 10 - 22H2)
