Rename the Machines
angelshurikan
Registration: Sep 22, 2015 - 08:47
January 26, 2016 - 09:05
I would like to rename the machines on the "WAPT Console", or at least change the description so I can find them more easily. Currently, if I change the name or description, it doesn't reflect the change.
Is this possible?
Nathanael
Registration: August 18, 2016 - 5:16 PM
August 18, 2016 - 5:20 PM
I'm also looking to rename the machines so I can easily distinguish and identify them.
Have you found a way to do this?
Thank you very much,
Nathanaël
August 18, 2016 - 10:52 PM
Currently, renaming the machine (Windows) works.
If in doubt, run `wapt-get register` on the machine if it doesn't work.
Perhaps a "refresh workstation inventory" from the console also works?
However, the FQDN name will change, and therefore its configuration package will also change; you will need to reconfigure your settings in the console.
Nathanael
August 19, 2016 - 09:37
Yes, changing the PC name in Windows does work.
However, our PCs are named with a number and not with the users' first and last names.
It's much simpler to find a PC by the name of the person using it.
We need to see which machine naming strategy seems most effective.
We could also include the name of the employee using the PC in the description, which would avoid renaming the PC and therefore having to redo the WPAPT configuration.
Thank you for your reply.
Nathanaël
August 19, 2016 - 12:26
So you can indeed use the job description, that's something that also works.
Nathanael
August 22, 2016 - 2:51 PM
Yes, I think I'll go with that; it's simple and practical (no need to restart the computer).
Thank you,
Nathanaël
