[SOLVED] WAPT issue: update-package
Maggle
Registration: March 20, 2024 - 2:22 PM
July 11, 2024 - 09:04
I recently updated my WAPT server to the latest version 2.5.5.X.
Since then, when I modify a package with PyScripter and do a "WAPT: update-package", there is no error or anything, but the package does not update with my modifications and the version in the control file does not increment.
It doesn't ask me for my certificate password or the admin account password for the console.
I'm not sure what could have changed, whether it's related to the update or my computer. I did install the latest version of the agent on my machine.
July 11, 2024 - 11:07
Hi Mathieu,
I think the command you're looking for is `build-upload`. `update-package-sources` is used to download a new version of the software, but there's no new version in the case of the `audit-local-admin` package, which only performs auditing.
Regards,
Maggle
July 18, 2024 - 4:43 PM
Indeed, that must not be the correct command being used. I'm using PyScripter and I only have this:
In my Run Configurations I don't have a build-upload option.
So I did a Run Configuration like this, with a build-upload -i to increment the package version:
And when it starts, it doesn't prompt me with a popup to enter my private key and then the console password:
I'm not really sure what I did to my console.
July 23, 2024 - 6:02 PM
Hi Mathieu,
we had quite a few calls regarding the build-upload feature in PyScripter due to the different execution contexts and authentication options [1]. We've removed it, and the new method is simply to have a console open and drag-and-drop the package onto the private repository (or to enable the package development tab in the view and use the functions there).
Regards,
[1] viewtopic.php?p=13957&hilit=build+upload#p13957
July 25, 2024 - 09:37
Hi Mathieu,
were you able to manage with my instructions?
Best regards,
